HR22 HD DVR | SatelliteGuys.US
HR22 HD DVR
rustolemite
67
Pineville, LA
Just bought a new HR22 already have 2 of them, this new one has been up and running for 3 days now but when you change channels you get a black screen for up to 3 or 4 secs till the picture appears on the new channel. Anybody else have this problem ? My older receivers don't do this.
Rustolemite
Check Menu-Parental, Fav's & Setup-System Setup-HDTV. If Native is On, setting it to Off will speed up channel changes (the same resolution will be used for all channels). The picture quality may suffer, but life is full of tradeoffs.
okay thanks will try that when i get home ... and it does seem to only have the delay with the HD channels
Hotpass Feedback
Pole mount
