HR23-700 with 771 error | SatelliteGuys.US
scottishknight
11
I have a brand new HR23-700 HD DVR box installed by DTV less than one month ago. They used the existing 5 LNB oval antenna and two coax lines. It is the only receiver I have.
Last night I started getting the 771 error on at least two channels: 278 Discovery and 229 HGTV, and there might be others. Other channels I looked at are working fine. A friend in my area is getting those channels okay.
The signal strengths were all in the high 80s or low 90s.
DTV tech had me switch the two coax inputs, reset the receiver (soft) and he reauthorized the box, and no improvement.
They scheduled a service call for next week.
Anybody have any "magic" that might help this problem?
Sorry, newbie here.
I'm not sure which ones I should be checking.
I looked at 3 or 4 of the signal strengths (by clicking on the plus sign) and they were all about the same.
Look at the overview Menu/Settings/Satellite/103c/99c
Check Channels 202 and 362 as well.. and see what Channels 480 and 481 feedback.
Has anything drastic happened? New building in the way.. tree falling in the path, high windstorm, heavy rain? Snow?
Sorry, newbie here.
You can check all satellites on the screen by clicking the +/- next to the satellite and then the TPs by the +/- next to the TP section. In your case, you need to check the strengths on 99 and 103 as Zynergi said.
Wires on DirecTV box
Ordered a am21
