HR23 Searching for new software continually..... | SatelliteGuys.US
kpoe
3
My HR23-700 receiver keeps trying to update the software but there is no progress in the status bar and eventually just reboots. This happened to me a couple of months ago and fixed it by taking it to a friends and connected it to their dish. The software updated right away! Now since there is a new software version I am having the same problem. Is this a dish problem? I have good signal from my slimline and have two coax cables coming down from the dish into the receiver (not SWM). Any ideas?
I have/had a H20 that did that recently.
I called D* they went thru checking things over and sent me a new recvr. At that same time I upgraded to a HR24.
If it works with someone else's dish this indicates a signal problem on the 101 satellite on your dish. Post back with ALL your 101 signals on tuner 1.
Here are the levels I am receiving:
Satellite Transponders (32 total at 101)
1-8 93 96 95 0 95 97 95 97
9-16 95 96 95 58 96 97 95 98
17-24 95 0 95 56 95 98 95 98
25-31 95 0 95 0 96 97 93 98
I was thinking there was a dish problem but I didn't know which Sat the update came in on.
Those numbers look fine, are you still having trouble or is everything working now ?
The receiver randomly displays the message to download software now or download later. Sometimes it may go 15 min then ask, other times it could be a couple of hours. This really baffles me how it will work on another sat dish.
Initial pictures of the HR24-100 and H24-700
