Hi Guys,
After several days of watching live tv, all seems fine now (after several RBR's and a system test that corrected 160 errors) HOWEVER, any recordings are still pausing every now and then (2-5 seconds). Does the same thing either with a recording or if I pause live tv for a few minutes and start it back again. Once I am caught up, all is fine again. Does this sound like strictly a hard drive issue and is so, could I just get an external HD (a DVR Expander)?? Keep in mind that all this started the morning after the latest firmware was downloaded--the receiver is less than 4 yr old (always stays in the entertainment cabinet with lots of airflow around it). Are there any tests I can do at this point??
Semi related question..............if the box is bad and an expander would not fix the issue, could I simply hook up a HR34 box or, is there more to that upgrade (coax/LNB, ect)?
Thanks!!
Thanks!!
