HR24 / H24 Software Release v.0410 / v.0412 9/21/10 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Receivers included in this release:
HR24-100 • HR24-200 (0410) HR24-500 (0412)
H24-100 • H24-200
Release began 9/21/10. (HR24-500 v.0412 began 10/7
The Contents of this Release: (Differences based on previous national releases)
New features
Cover Art for programs in the playlist and guide
DirecTV Cinema enhancements
Smart Search now gives Top Matches
Updated
MRV
System Test
Improved stability
Notes
DIRECTV Cinema Queue is now integrated with Playlist
Maybe this is the update that will enable DOD without Internet connection?
Sound drops periodically while watching recorded programs since this update.:(
Ramy said:
All my dvr's dd sound has done that no matter what the update or the model of dvr.
Yep. I have read about sound drops from the play list. It is only on one of my HR24. Happens every ten minutes or so. Not bad enough to be a pain......yet.
I thought you were doing the CE software, guess not .
When you posted the software version, I thought that the version was higher than that.
I checked and the CE is at 0x415 .
Fortunately I haven't had any audio drop outs.
Same here. New CE, and NO audio drops
THe -500 was left off the 0410 release, and now is receiving 0412.
The notes should essentially be the same. In the cutting edge release of 0412 there was nothing different in the notes, just under hood tweaking. That said I am combining the threads for 0410 and 0412, since they are essentailly the same, just getting something out to the -500 series.
Thanks for posting it elwaylite.
Doubt if it's caused by the new software I received on Weds. (0x413) for the HR24 but last night was a bad night for recordings. After 10pm any show recorded was unable to be watched,. No audio/video packets received message came up.
Did a front panel reset this morning and new recordings are fine but interestingly all the recordings that had issues have vanished from the playlist.
Whole Home DVR Question
Tailgate help for a Direct TV convert
