HR2x CE Release 10/14 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,047
452
Central Michigan
Systems in this CE
HR20-100 • HR20-700
HR21-100 • HR21-200 • HR21-700
HR22-100 • R22-100 • R22-200
HR21Pro • HR23-700
HR24-100 • HR24-200 • HR24-500
Window of opportunity to download:
Friday, October 14, 2011 11:00PM - 2:30AM ET
Saturday, October 15, 2011 11:00PM - 2:30 AM ET
Risk Level for this Download:
Low Risk
New features
None for this release
Improved/Updated
None
Notes
This release features the new HD UI.
You may need to re-enter IAMANEDGECUTTER to send logs
This CE may remove your guide cache. Please allow up to 24 hrs to restore your full 14 day guide.
Your STB may restart during idle time within the first 24-48 hours of CE download
You will lose your guide cache when reverting from CE to national.
Please do not report sluggish issues or missing search results within the first 12 hours after download.
"Under-the-hood" and "stability" improvements are expected with every release and are not noted here.
New features
None
Improved/Updated
{CE 28:01} 0x04FD
UMightLike!
Interactive content downloads separately
{CE 28:03} 0x0552
HDGUI
{CE 28:04} 0x559
Fixed red screen issue
04D1 is what mine is downloading...
*edit* thanks for the replies - rebooted and it's downloading 0570 now.
I give up. Both of mine keep grabbing the NR and I need to use my DVR in a few minutes. I may try tomorrow
0570 coming down to all 4 of my receivers. Loving the HD gui. My brother's jealous, but he's not really savvy enough to get how to download it. Ah well, it should go NR soon enough, I'd think.
It'll be interesting to see if/when the software download/startup pages go HD... not that it makes any difference at all, but its kind of jarring going back to the stark blue screen(s) after the sweet dark HD
the HD GUI is only in the beta/CE; which can only be D/L on FRI & SAT between 11p - 2:30a ET and only when announced and only for the models listed that particular wknd.
I tried many times last night to do the download at the proper time. When I entered the code, I could only enter the first three digits and then the receiver stopped responding to the entries. I did this as soon as the blue screen came on. Any help would be appreciated as I am fairly new to this. I have entered IAMANEDGECUTTER and I think I am doing everything correctly. IDEAS????
THX, Don Gurian
H21 - H25 CE Release 10/14
CE's for the first weekend of fall
