HR2x / R22 CE Release 0X02EB 3-20 & 3-21 | SatelliteGuys.US
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
Systems in this CE
HR20-100• HR20-700
HR21-100 • HR21-200 • HR21-700 • HR21Pro
HR22-100 • HR22-200 • HR23-700
R22-100 • R22-200
Window of opportunity to download:
Friday, March 20, 2009 11:00PM - 2:30AM ET
Saturday, March 21, 2009 11:00PM - 2:30AM ET
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the CE Chat on Friday nights:
cechat.satelliteguys.us
The Contents of this CE Download: (Differences based on last National Release)
  • Items from CE:19:01 Moderate Risk
  • Items from CE:19:02 Moderate Risk
  • Items from CE:19:03 Moderate Risk
  • Items from CE:19:04 Moderate Risk
  • Items from CE:19:05 Moderate Risk
  • Items from CE:19:06 Moderate Risk
  • Items from CE:19:07 Moderate Risk
New features
  • 02 - New System Test and Info Screen
  • 02 - {FORMAT} button enabled while playing 1080p content
Improved/Updated
  • 01 - Recording robustness
  • 01 - Support for more actors in programs
  • 01 - Video issues playing back 1080p content at lower resolutions.
  • 01 - Audio drops/out of synch after using trickplay and jumping to bookmarks on MPEG4 HD channels.
  • 01 - Mediashare:
    • Issues with only 1 photo in the photo playlist.
    • Incorrect duration for large audio files.
    • Other Mediashare fixes/tweaks.
  • 01 - Misc. UI fixes/tweaks
  • 01 - XM channels:
    • Loss of background image
    • No music info when exiting screensaver
  • 02 - Corrected missing HD icon in My Playlist
  • 02 - Improved HD icon with manual recordings
  • 02 - Improved consecutive channel ups
  • 02 - MediaShare: Fixed aspect ratio
  • 02 - MediaShare: Improved Trick Play bar
  • 02 - Improved stability with interactive channels
  • 03 - Fixed occasional searching for satellite signal when tuning HR20-700
  • 03 - Fixed video freeze up when using Trick Play HR20-700
  • 03 - Fixed loss of background when using Interactive Applications
  • 03 - Improved Interrupted Manual Recording Display
  • 04 - MediaShare:
    • 04 - Lockups when viewing pictures.
    • 04 - Lockups when viewing streaming video.
    • 04 - Aspect ratio changes when streaming video.
  • 04 - Set Top Box tunes to channel 201 after software download.
  • 04 - Audio Synching on HD recordings after jumping to bookmarks.
  • 04 - Parental Control lock causing DOD Homepage viewing issues.
  • 04 - DOD program search program info takes you to wrong screen.
  • 04 - "Sluggish" UI behavior – especially in DOD navigation.
  • 04 - QuickMenu/On Demand addition options added.
  • 04 - Added remote codes.
  • 05 - MediaShare: Improved display for songs/titles
  • 05 - Fixed Blue flash when performing Trick Play on live TV
  • 05 - Fixed Keep at Most setting
  • 05 - OSD improvements for PPV
  • 05 - OSD improvements for deleting in To Do List
  • 06 - Searching for satellite signal HR21-700
  • 06 - System Test Issues
    • [*]Does not complete
      [*]Dish Pointing Failure
  • 06 - Single Frame Forwarding
  • 06 - Updated MediaShare failing when accessing pictures and music
  • 06 - Loss of Video when switching to HDMI
  • 06 - Interactive Applications
  • 06 - Loss of background when accessing Widgets
  • 06 - Improved on screen display for pay-per-view
  • 06 - Additional System Test improvements
  • 06 - 1080p on screen display
  • 07 - Screen background issues
  • 07 - UI Polishing
  • 07 - Stability
Notes
  • You will lose you guide cache when going between national and this release
  • When reporting issues with 1080p, please include the TV resolution information reported from the Miscellaneous Options screen as well as your TV model number
  • Please make sure to first attempt to tune to an OTA channel before running an OTA signal strength system test
  • 06 - Widget Keyword will be reset - Do a search for WIDGETSON to re-enable
  • 07 - Widgets are active again with this release
  • 07 - Guide cache may be lost when downloading
Downloading on both my HR20's now. Have to watch basketball off the web for a few minutes while these complete. :)
everything looks normal. pretty speedy though. never been this speedy so soon after a download :up
Hopefully it is NOT a NR Canidate.
I fail the system test and in looking at the CE Chat transcript that was sent to me overnight others are having the same issue.
