HR34 CE Release 1/20 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,047
452
Central Michigan
Systems in this CE
HR34-700
Window of opportunity to download:
Friday, January 20, 2011 11:00PM - 2:30AM ET
Saturday, January 21, 2011 11:00PM - 2:30AM ET
Risk Level for this Download: Medium Risk
New features
None
Improved/Updated
Under the hood
Notes
If you revert to National, it will be to the blue UI
You will need to enter IAMANEDGECUTTER keyword search if first time STB updated to HD UI
You will lose your guide cache
Please allow up to 24 hrs to restore your full 14 day guide
Your STB may restart during idle time within the first 24-48 hours of CE download
Please do not report sluggishness or missing search results within the first 12 hours
Please send logs along with all reports, including MRV issues
Previous Release Information:
"Under-the-hood" and "stability" improvements are expected with every release and are not noted here.
New features
Under the hood
Improved/Updated
{CE:03:01} 0x539
HD User Interface
Issue: Several Pinks Screens - Solid Pink after DL & before checking Receiver
Issue: 30Slip - Can't get beyond one Slip at a time. And that first one even goes backwards.
Issue: More Info Button - Clicking Info Button does not default to highlighting the Channel Banner More Info Button
Issue: Dish Alignment Test - Run System Test Get Dish Alignment Test not run. The dish alignment test was not performed. Diagnostic Code 74
Issue: Recording Tips - Recording Tips are showing up while Settings/Display/Preferences/Recording Tips setting is in the OFF Position.
Issue: PlayList Date Column - PlayList Date Column is too narrow to fit a Full Date
Issue: My DIRECTV - What's on Now - Two of the four What's on Now are NOT On Now!
Issue: Deleting Recording - Deleting Recording from the Program's More Info screen doesn't always take you back to the PlayList. Instead, you are often booted to Live TV or some other GUI screen that's not the PlayList. (A carry-over issue from the SDGUI)​
So .... have they gotten anywhere from the list that you posted last week ?
How many of these are the same and how many have been resolved ?
This looks like something that they are gonna be working on for a while, nothing thats gonna be resolved with one CE, but over some time.
FIXED
Issue: FF Time/Progress Bar - Time/Progress Bar arrow & clock does not progress going forward or backwards.
Issue: Guide Distortion - Get Guide stretching distortion with Settings/Display/Preferences/Scrolling Effects setting is in the OFF Position.
Issue: System Test - No A/V in PIG - The PIG loses audio and video while running a System Test.​
What strange, the System Test - No A/V in PIG Issue has moved over to the Hx2x!
FIXED
Well, it's good to see some of them getting resolved ...
From what I remember, you never have a or v when running a System test, your changing over tom the Signal Strenght side of things, I don't, think I have ever has A/V when running the test.
Missing Channel Icons
CE's for the Weekend of 1.20
