HR34 CE Release 2/24 v.0544 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,047
452
Central Michigan
Systems in this CE
HR34-700
Window of opportunity to download:
Friday, February 24, 2011 11:00PM - 2:30AM ET
Saturday, February 25, 2011 11:00PM - 2:30AM ET
Risk Level for this Download: Medium Risk
New features
None
Improved/Updated
None
Notes
If you revert to National, it will be to the blue UI
You will need to enter IAMANEDGECUTTER keyword search if first time STB updated to HD UI
You will lose your guide cache
Please allow up to 24 hrs to restore your full 14 day guide
Your STB may restart during idle time within the first 24-48 hours of CE download
Please do not report sluggishness or missing search results within the first 12 hours
Please send logs along with all reports, including MRV issues
"Under-the-hood" and "stability" improvements are expected with every release and are not noted here.
New features
Under the hood
Improved/Updated
{CE:03:01} 0x539
HD User Interface
{CE:03:05} 0x542
Under the hood
Pink screen issue
Dish alignment test
What do you mean revert to national? Can I just do this the normal way I did my HR24 before the HDGUI was available by resetting and hitting the button combination and have the new GUI when it boots back up?
You can do it the same way as you've been doing. What reverting to NR means is that if you download CE and then decide to switch back to NR you'll go back to the SD blue guide.
Hi guys, I want to apologize in advance because I'm new to the forum and to CE. I just want to make sure that when the new firmware is released tonight for the HR34 all I need to do is the 02468 method to download the new firmware. Will this give me the new HD user guide and will this erase my DVR library?
Welcome to the Site !!!
First off, please read this :
http://www.satelliteguys.us/directv...2-directv-cutting-edge-program-terms-faq.html
Then, Yes, you use the process you mentioned.
You should NOT lose any Recordings.
Been stuck on the old blue gui for the hr-34 since the install a week ago. The old blue had issues with rebooting the box during recordings. At least I've lost that ugly gui - unless I have to revert.
I did my first CE download and it went off without a hitch and so far everything seems to be working perfectly. All of my settings were retained. Main differences I've noticed from the old software is that the menus are loading much faster, but the channel changes seem to be a bit slower. My feedback probably isn't of much help since I only have the one unit and not using the whole home setup.
only issue i see is a huge lag when scrolling through the guide. terrible. everything else so far seems good. and despite the annoying lag in the guide i ain't going back to the old gui :D
Issue: Several Pinks Screens - Just a Few Seconds More was Pink, follow by a solid darker pink. These occur before returning to normal with the Running receiver self-check screen.
Issue: 30SLIP - Can't get beyond one Slip at a time. And that first one even goes backwards. Keywording 30SLIP get function to work.
Issue: More Info Button - Clicking Info Button does not default to highlighting the Channel Banner's More Info Button
Issue: More Info Deletion - Deleting a Recording from the Program's More Info screen doesn't always take you back to the PlayList. Instead, you are often booted to Live TV or some other GUI screen that's not the PlayList when you have looked at other GUI screens while watching the Recording. (A carry-over issue from the SDGUI)
Issue: Scrolling Effect Switch - The ON/OFF Switch is not recognized.
Issue: Recording Tips - Recording Tips are showing up while Settings/Display/Preferences/Recording Tips setting is in the OFF Position.
Issue: My DIRECTV - What's on Now - One of the four What's on Now are showing correct correct posters, but time for one is 6:00a at 11:30 PM
Issue: Audio/Language - Setting in BLANK in More System Info screen wen set to English
Issue: DirecTV2PC - Info - Well a couple of weeks ago CE got the HR34 Recorded programs to show in DirecTV2PC, but each Recorded Program Info is mark Unknown on all those that I checked.
Issue: PlayList Not Staying Current - PlayList is still not being updated when changes are made to Client PlayList. This started when 5B3 was installed to my HR24s.
Issue: Series Manager Boolean - SerMgr Boolean for THIN MAN TTITLE &{movie} - While it was able to find today's TCM movie, the HR34 did not schedule it to Record. SerMgr Settings was set to 'Both.'
Issue: Guide Data Lost w/Single Reset - A Menu/Reset does refresh PlayList, but all Guide Data is lost. This is another carryover repeatable.​
Is this REALLY an issue, it happens on all recvrs IF it what I'm thinking your saying.
It has a short time that it goes pink when its going thru it's reboot process, then thats it .... everything is fine from there .. or is there more to it than just during reboot ?​
Actually it doesn't really happen to all my receivers (hr24)but it's after you do a reset. The startup screen is pink which really isn't a big deal. But druzifer is having a lot of issues. I've reseted a few times today but can't get rid of the guide lag when I press page up or down.
For the scrolling effect I had the issue but after selecting on then exit,went back in and selected off again and it worked. everything else so far is ok. Druzifer I'll keep looking at the issues you posted to see if I can produce any of them on my hr34
Only happens on my HR34. If it happen on all, then I would agree, it was a bootup process.
Ok, see I get the pink screen on my recvrs, both HR20 and HR24, for a small part of the reboot process, it's doing some kind of check and then it moves on and its not an issue after that.
Were probably talking two different things, I don't have a HR34 to try and duplicate your issues, sorry.
Going to see if I snag this tonight. I got installed today with one HR34 and 3 H25's. That guide on the 34 is awful compared to the H25.
Congrats digi on getting the HR34 i have had it since last friday and have loved it and finally got the HDGUI last nights ce :)
CE's for the weekend of 2.24.12
How to revert to national?
