HR34 Sluggish | SatelliteGuys.US
HR34 Sluggish
brphoto
14
Is anyone else having a problem with the HR34 being very sluggish? It take 20-30 seconds for the guide to load. Sometimes it takes that long for channels to change as well. It's very inconsistent. Done a red button reset. Sometimes that helps for a while. But it comes back.
i had these same issues. only advise i can give you is to try and see if directv can switch it out for a HR44.
Mine is slow too. Not 20-30 seconds for guide, but the lag on key presses is unacceptable for a modern device. Worse on nights we are recording 3-4 things at once. I have lost count how many times I went to a wrong channel when typing in the channel number cause I think the unit is not responding and I hit the key 2-3 times before I realize it is working.
My HR34 worked fine till the last couple of firmware updates.
Cinemax for $6.50?
MLB Extra Innings Preview?
