HR44-200/500/700 Genie
Window of opportunity to download:
Friday August 1, 2014 11:00PM - 2:30AM ET
Saturday August 2, 2014 11:00PM - 2:30AM ET
Risk Level for this Download:
High Risk
New features
Smart Search key changes
Background Send Report
Improved scrolling on poster views
Improved/Updated
UTH
Background Send Report Feature
Press & Hold List button for 5 seconds
Double-bonk sound will be heard to indicate start of process
In some cases, the double-bonk is suppressed if the STB is plugged into a Dolby Digital supported device
and the Dolby Digital audio track is selected
Check Menu > Settings & Help > Settings > Info & Test > More System Info for status
Code will be seen next to 'Completion Code' list item, check back as it may take a few minutes to complete
Number at end of report key indicates status
0 – Success
9 – No Internet Connectivity
10 – Transmission started
11 – Transmission in progress
12 – Transmission timed out
High Risk
New features
Improved/Updated
UTH
0 – Success
- There is still a one-report per hour limitation
- Please try and press & hold the LIST key as close to the actual problem being reported as possible
- Please continue to provide the report key when reporting problems
- PLEASE MAKE SURE TO REPORT ALL ISSUES WITH THIS RELEASE
- You may lose your guide cache
- Please allow up to 24 hrs to restore your full 14 day guide
- Your STB may restart during idle time within the first 24-48 hours of CE download
- Please do not report sluggishness or missing search results within the first 12 hours
- Please send logs along with all reports, including MRV issues. When possible please use REPORT ALL.
