HR44 | SatelliteGuys.US
HR44
AZ.
9,721
21,677
crazy
Anyone having problems with the apps from time to time? Not loading?
Either going there off menu, or just a click of the right arrow....All I get is, Checking connection, then loading apps along bottom....and nothing after that on the screen...
Yep iternet conection just fine and tested....
Any thoughts?
I get them to come up but when i click on one i get a faint error message at the top of the screen something about server or file not found. happens on both hr-44 and hr-24
any perticular app or all of them ?
I am currently getting Apps not available at the moment, please try again later.
Also checked to see that the internet is connected, it is, I d/l something from 1002
Yep. My apps aren't working either with the HR44. Hit menu, says connected. Every time I hit the right arrow it says, connection lost. When I reconnect, it says apps not available.
S~
OK,
Someone at the "other" site with the same issue called D* support and was told that wired is no longer supported, only wireless. That seems ridiculous. I'm wired for a reason. Apps are now working, but I have to connect every single time to get there. They are not working on the clients, as network is only controllable from the HR44.
S~
Well, I just tried again when I saw the replies here, my Apps ARE now working.
Fwiw, I'm using my HR44 and its running Wireless.
Switch to DirecTV a good idea?
New customer having second thoughts...
