HR54 tuner issues | SatelliteGuys.US
HR54 tuner issues
pinkcookies26
62
9
Twice now I have turned on the receiver (HR54) and it was recording one program, I went to turn the channel and at first it wouldn't let me and shows me that it is recording a program, then another tuner shows up and says it's unassigned and to use that. So I try that option and then it tells me it's unavailable. So basically I was locked into that one program that was recording unless I stopped the recording. I do have an HR24-500 in the bedroom, don't know if that has anything to do with it but I figured that would just offer more tuners. Any help is appreciated. Thanks.
Like mdram said, do a reset and see if it is any better ...
The HR54 should have 5 tuners available to you, so that shouldn't happen.
Often times a Reset clears issues.
C61K Cutouts. Any cure?
Genie Upgrade
