HUB Channel | SatelliteGuys.US
HUB Channel
barco13
70
Kansas City Metro
Quick question that I couldn't seem to find when searching. It looks like the HUB channel should be on 179 if you have America's top 250? I currently have AT 200. When I go to "all channels" I do not see 179 listed. Does Dish still carry this channel? Thanks!
Thanks! It seems weird, when I go to all channels I can see other channels I'm not subscribed to, but not this one for some reason. I'm dropping Blockbuster since I am not getting my $10 worth out of that and I have had enough issues with it. But I thought I would trade that $10 for the AT 250 and get some additional channels.
Not every channel is visable when it's not in your package. I have never seen a good explanation as to why some and not others. Never go by that, go to the Dish site and look at the packages to see what they have. (not that it's always 100% correct)
If you don't watch the channels in BB, it may be worth dropping it and going to Top250 then.
boba said:
I get it in Welcome pack sat 110 trans 11.
Yes, The Hub SD is also in the $14.99/month Welcome Pack (http://www.mydish.com/support/channels/packagewelcomepack.aspx) and $24.99/month Dish Family. The Hub (SD and HD) is also in Dish Latino Dos ($44.99/month) and Dish Latino Max ($57.99/month). Otherwise, it is in America's Top 250 ($69.99/month). Here is the link to channel lineup cards: http://www.mydish.com/programmingguides/
This will allow you to see what you would also gain by adding AT250 and what you would lose by dropping BB@Home.
New Hopper - Sling Adapter Invalid - EHD not working
Remote 40.0 using AUX volume as default vs TV??
