hughes net lnbf on corotor | SatelliteGuys.US
vassho
71
After racking my brain with trying to hook up my 5th BUD using a corotor as im running out of ku lnbs
I just remembered i have 3 Hughes net systems stored away in the barn never opened
I know the lnbf are linear just wondering if the lnb off the hughes net systems will hook up to my corotor i have enough wave guides i think to make it work if it wont hook straight up, but thinking i have enough room on the corotor to do it
I am using one of the first chapparrel corotors and will just use the servo to switch polairtys on my dsr922
would this work out?
I know Hughes made a decent lnbf for these systems
I was just going to sell them on ebay one day but if i can get some use out of one of them
I think i will just go that way
as you all know this Hobby can get expenisive and all the time i am given a BUD or get a new one dirt cheap
I just have to put it up they are addicting
The only info on the lnb is 10.95-12.75
its a fss which is fixed satellite service which i think doesnt really matter as its a KU LNb not KA as Wildblue has
HD -- Correct me if I'm wrong
use a bud for fta satellite
