Well, that doesn't surprise me. The HN9000 is designed to ONLY power a Ka-band system, and has a 73 watt power adapter. The HN7000S modem 64 watt adapter powers various Ku-band systems, including the one you got from the gas station. That's two different power adapters sending several different operating voltages at several different amperages - to their respective outdoor units. You don't mix & match & hope for the best. So in effect you tried to power up a Ku-band system with a Ka-band modem. Hopefully you didn't burn something out.I tried connecting a HN9000 modem to it. all that happened was the power light started flashing blue then after 20 min flashed blue really fast. This modem was working fine when I terminated my service a year ago. It never flashed before.
Heaters that are not specific to a piece of equipment usually cause more harm than good. Feedhorns seldom ice up anyway, and a cup or two of water usually cleans it off. But a permanently mounted heat tape is a permanently potential source of interference. And interference - at best - slows down the internet connection.
And the fact that the System LED didn't illuminate doesn't mean a thing. It was the incorrect voltages and amperage sent to the ODU that you should worry about.
//greg//
You might be ascribing characteristics to this device that don't actually exist. Of course, you can prove me wrong with the tech manual. But the typical VSAT dish heater cannot "sense" the presence of ice. Not that it's impossible, but the cost at the VSAT level would be prohibitive. It's almost certainly controlled by a simple thermal switch. Most of them turn on at +35F and back off at +55F. It doesn't have a clue if actual precipitation is involved.That "heat tape as you call it" is designed for this dish. The reflector on the dish has a unit that senses ice build up and kicks a heater on. The tie strap that is around the feed horn is connected to the heating element and deices the LNB. It is perfectly safe and commonly used even in the area I am in "Mississippi" for critical applications like pipeline controllers. In the Northeast they are used on almost everything. I have never known one to cause any type of interference.
Second; dish heaters are intended for use on metal only. That said, the photos don't reveal the composition of the reflector OR if there are even heat strips on the back side
Third; the never ending heat/cool/heat cycle - particularly in the absence of precipitation - necessarily advances decomposition of the insulation. Decomposing insulation permits the leakage of an electrical field, more than two electrical fields in the vicinity of a VSAT dish constitutes interference.
I don't want to discuss ROTV heaters, as no transmitter is involved. But VSAT heaters are intended for remote/unmanned sites. Military/commercial satellite facilities avoid heaters as well. Dumping the dish and hosing it clean is the preferred method. In extreme conditions radomes are employed, but seldom if ever direct heat. Foisting dish heaters as a "value-added option" on otherwise unsuspecting VSAT customers (who would otherwise use conventional cleaning methods) - may not be criminal. But I definitely consider it unethical.
Oh, and polarization change on an OSIRIS/TGx is accomplished with a 45 degree shim
//greg//
Limited time offer
