hughes & xbox 360 | SatelliteGuys.US
hughes & xbox 360
btwink
7
whats the best way to hookup xbox live for the 360 to my computer and my hughes sat?.the 360 is only about 25 feet away.thanks for your help!
i have xp media center,can i hook everything together with a ethernet cable or do i have to use a wireless router?.thanks
i bought the linksys dual band wireless a+g broadband router.so i need to run the ethernet cable from there to the xbox or would be better to buy the xbox wireless adapter?.thanks!
how would i go wired?.is there an ethernet adapter that has one feed in and two going out.thanks!
Yep, get yourself a router. Cross over cable can work but you need to get IP addresses and since you are asking, make it easy on yourself and get a router.
