I have a couple of Hughesnet/Direcway .78M dishes. Anyone played with these for multi-lnb/multi-satellite reception. Any ideas would be welcomed.
I've got a Hughesnet, and have been told in the forums here, that I can use the Hughesnet LNB.
It show 11.750 - 12. ghz on the lnb. I've removed the radio module, and tube that connects to the LNB. Anything else I need to use this for FTA? There's an opening now through the LNB where
the transmit arm attached...
I would close up the hole with heavy tape or a piece of plastic and let 'er rip.
Is your 10' Channel Master mesh or fiberglass?
I love mine and I use it stationary so I use it for the programming that I record for the family from the computer.
Take a look at some pictures of my setup if you like.
Free To Air Satellite | thenetbuilder.com
Limited time offer
