hughesnet dish | SatelliteGuys.US
hughesnet dish
crankbait
37
I have a hughesnet dish 33 inches wide 28 inches tall, is it large enough for ku band. I am trying to recieve 97 west, if so will the lnb that came with the dish work. thanks for any reply.
crankbait.....yes and yes.
There are some very recent threads about using Hughesnet dishes, and if you do a search for Hughesnet in the FTA section you'll find all the info you will need. That setup will work great on 97W.
I noticed the dish in the picture has a single arm that the lnb is attached to , my dish has two square tube arms that the lnb is attached to are they both the same? thanks
how to move a satellite dish?
CL FREE Viewsat Ultra (Renton Wa)
