What would I expect as a install and speeds of the home 1.0 mbps package from Hughes. Would I later on be able to upgrade to the gen 4 sat?
1 mbps is barely above dial up let alone peak hours, I bet its worse then dial up durring peak hours. As far as the speeds, they can range from the full 1mbps in the middle of the night (when you're normally asleep) to barely above dial-up during peak usage hours (when you ordinarily want to use it).
//greg//
Given the punitive DAP restrictions with Exede, I'd say waiting a few months for Gen4 would be the more sensible option.Also I would go with Excede if you have to get it or wait for Gen4 sat for Hughes.
When is the gen 4 service going to be launched ?
The satellite has been delivered to the launch site and is currently next in line, tentatively June 19th. It seldom takes less than 30 days to position and test a newly launched telecommunications satellite before it can actually be commissioned into service. So to be on the safe side, I'd say August.When is the gen 4 service going to be launched ?
99% of new US installs are Ka. most likely, the GEN4 change out would be the radio and modem, and the dish would be reused. Admittedly, most of a system cost is in the radio and modem.Unless it includes the Ka-Ku dish and mount,
Limited time offer
