humax reciever wont work | SatelliteGuys.US
star1234
5
i have no idea what I did wrong, but would really apreciate your help!!
I have a humax IRCI 5400Z reciever. anyways yesterday it was working fine. then when I went out to the yard and came back some of the channels weren't working (its possible that my kids pushed the dish ?????)
anyways I did a channel search and then it found 4 new channels, but now none of the other channels work.
HOW CAN I GET MY CHANNELS BACK?????:confused:
THANKS!!!
i had hot bird and ara bsat and nilesat channels I think.
as for my satalite i don't know what kind it is except that it is really big and old!!
Ok, looks like you are in Europe.
What are the channel names of the 4 "new" channels?
Can you name a couple of channels you got before?
This way we can figure out if the dish moved to another bird or not.
You better ask your kids :D
I asked the kids and they said that they didn't touch it and it doesn't appear to be moved. Could a slight tap make it come out of whack???
The channels that I am still getting are some sport channels that I think came with a card that my husband bought. but the other channels were all free channels (i know because they worked without any card)
some of the channels I used to get were MBC1, 2, 3, and 4 Spacetoons BBCworld and a bunch of other channels but I dont know the names because I don't watch too much tv anyways.
thanks!!!!!!
by the way im not in europe im in SAUDI Arabia
I apologize, i just took a good guess because of the satellite names :(
A slight tap shouldn't move the dish at all.
Are the sport channels Al Jazeera Sports 1/2/+1/+2/+3? If yes, you are still on Nilesat, i guess, so at least one satellite setup is still correct (hopefully).
yes the sport channels are al jazeerah.
i think the problem is that I did something wron when I tried to search for new channels because thats when everthing came up missing before that there were still some channels is there a way to undo whatever I did wrong?????
thanks
system seems to have died
Bad Motor
