I Can't Record More Than One Series At A Time – Help! | SatelliteGuys.US
jyafink
54
When I try to set more than one program to record in a series it won't take. It shows up under prioritizer but not in the to do list. When it comes time to record, it won't do it. I have had one show recording in a series for months with no problem but it won't let me set a second one. There is no conflict between the times of the two shows. How do I set more than one program to record in a series?
What model DVR? And, what series are you trying to record? Can you setup any other series or is it just one particular one that you can't set?
My bad, this is my second post tonight that made me feel stupid. My wife told me to set the show 24 on Fox to record in a series. I tried to do it based on tonight's Sunday showing but just found out this was a special season opener day and the actual time slot is Mondays. I just set it to record in a series on Monday and it takes it just fine. Since there will be no other Sunday showings, that's why it would not take. Thanks for responding though!
DVR Always Defaults to 480i Resolution – Why?
Totally disgusted
