I Need Help On Ia5 | SatelliteGuys.US
I Need Help On Ia5
frezer
2
I GOT SAT CRUISER DSR - 101 PLUS + SATELLITE RECEIVER
AND MY FAQ IS I JUST CANT GET NOT IA5.
WHEN MOVE MY DISH I ONLY GOT S 40 Q 0 ON IA5 97W
CAN ANYBODY TELL ME WOTS WRONG .
OR DO I HAVE TO BUY NEW FTA RECEIVER TO GET IA5
THX
:no
Try rotating your LNBF (skew) as you watch the signal quality screen, you can also try moving the LNBF in its holder closer or further away from the dish reflector.
I had a problem trying to get Galaxy 4R. I5, G4R and AMC4 are so close that you only need to move the dish slightly to get the next satellite. Are you possibly picking up a signal from one of the neighboring satellites?
THX
:no
Couple thoughts
-caps lock can be your friend
-putting multicolors isnt going to get better results...and its hard on my eyes to read
You didnt list your location, so we can verify if your elevation and skew numbers are right. It takes some time to get results...a little movement can make a big difference
Help! Problem with Using Switch and Motor
Satellite Motor GS3100
