I need help recording to DVD | SatelliteGuys.US
M
mfegley
Guest
I have the 10-250 hooked up by composite to an A/V receiver and this hooked to the TV by composite. I need help in figuring out how to wire to DVD recorder to record from the 10-250. Any suggestions would be appreciated.
Mike :confused:
Another question
Does anyone know if the 10-250 outputs from both the composite and component video outputs simultaneously
It does, but anything on the composite ports would be a lower quality output as you might expect. You cannot output from component and and HDMI/DVI at the same time so your suggestion is really the only way.
Locals Question
Just Board
