I need suggestions for new dish | SatelliteGuys.US
sobonefnet
322
2
PA
I currently have a single LNB dish (very old) and a H20 receiver. I am moving soon and would like to upgrade to a triple LNB so I can receive my locals and HD programming. Can you suggest an inexpensive route for me to go? I just have one receiver.
WHICH "triple LNB" dish did you have in mind???
The oval PIII dish (about 18" X 20") will NOT work for HD prog.
The dish you really need is the slimline - since I have NO idea what local market you're in, you'll either need the 3 or 5 LNB version.
Since you say you're moving, why don't you just have D* do a mover prog for you. The dish upgrade needed for your area would be FREE, as well as you would most likely qualify for a FREE HD DVR.
Well this is for a "second" home I have.
So for HD - I need slimline?
Local market: Altoona, PA
I can get Altoona HD locals. OK - looks like I will start shopping for a slimline. Any inexpesive sites for these??
May want to check your local Craig's list too. Make sure that any dish includes the monopoles (support brackets). Have seen them from $50 on up, but I wouldn't pay more that $75 delivered.
What type of Playlists is Media Share Looking For?
