Hi Guys,
I bought my equipment from Pete (Winegard Dish and a SG2100 motor) and connected it to a Pansat 2500a with a universal LNB and an old Sony DTV LNB and a 4x1 switch.
I entered the settings below, moved the dish via USALs and positioned my dish manually and am getting great reception 80+% on AMC5. But when i try getting other satellites using USALs i get nothing. When the dish is moving i can see quality go up and down as its passing a satellite along the way. Unless my pole has moved and not plumb which i doubt, what steps should i take to diagnose the problem. Also, where should I go to get frequency, polarity, and S/R information for all the satellites.
Thanks for your time!
Zip.= 22066
Lat./N.= 39 deg. Long./W= 77 deg.
True South satellite= AMC-5 at 79w
Distance to satellite= 37460 km (not needed)
Elevation of dish (if not using a motor mount)= 45 deg.
Motor mount elev.= 51 deg.
Dish (on motor mount) elevation=24 deg.
Magnetic deviation = +10 deg. so if using a compass aim at 190 deg. for true south.
I use the below to aim at AMC-5
Empire Sports
11808 freq.
H Pol.
4164 S/R.
Zip.= 22066
Empire Sports
11808 freq.
H Pol.
4164 S/R.
