I test fit the 'Big Sat' dual Ku band LNB to the P* | SatelliteGuys.US
Shawn95GT
Tivo fanatic
2,278
Phoenix, AZ
I think it's going to work out pretty good. It has a fatter neck on it than the D* LNB but with the way my LNB arm/mount is I don't think it makes much difference. I'll have to play with sliding the LNB front to back to optimize it. Of course I took some pics :). Check out the slider cover for the cable hook-ups.
Once I was happy with it I put the D* one on there for dish pointing purposes (110).
The CoolSat should be here tomorrow :D
It's looking good Shawn! My Coolsat should be here within a few days as well.
What kind of paint did you use to paint the dish? I have a few of these dishes as well, so I am interested in how it works out for you.
Dave
I used some rattle can from Home Depot. I'm going to get another can to touch up. As you can see, my dirty fingers turned the bolt heads dark :o . For good measure I'm going to do a coat of flat clear on the dish face.
Best LNB for FTA
KC, MO fta
