navychop
Purveyor of the Finest Encabulators!
My boss was having trouble with his computer. The machine is lightly used- email and very little web surfing, maybe a bit of access to an accounting program and very little WP. 5 years old, XP Pro on domain network. Kept getting an error msg about his video card (nvidia 64) driver, NV4_disp. No more recent driver was available, but I uninstalled it and reinstalled it.
Then I ran Windows update, and decided, foolishly, to let it install IE7. Now IE will not connect, says there's no connection to the internet. So I installed FF 2.0.0.4 and it (once) gave an error msg about missing some file, but loaded and just sat there. So I uninstalled and installed FF 1.5, thinking maybe I had a bad download. FF starts, address field stays blank. I can hit home or select or type in a URL, it just sits there with a blank white page.
I tried to force down a reload of IE from the server, but it goes into some loop with an error msg about no such (unnamed) file at C:\PVSW\temp0 (Pervasive SQL 9 SP1).
I cannot buy him a new PC because they all have Vista. We cannot use Vista because our accounting system will not support it until, maybe, October 2008. That's right, October 2008! I've got a call in to see if that's a typo on their web site.
I can't reinstall the OS because someone ripped the sticker off of it that has the Product Key. I MIGHT be able to find a new copy of XP Pro and reformat his hard drive and start over. Wonder if it's worth it for such an old machine. I'd probably replace the video card just on GP if I did that. Or I build him a new one with XP Pro, assuming I can find it. Or buy a refurb real cheap that comes with XP Pro.
Doing a DL of IE7 on another machine and moving it to his does not seem to be an option- MS requires validation and apparently just installs IE7, doesn't give you an install file to move and use elsewhere.
Any ideas on how I might get IE working again? This problem must be resolved tomorrow.
