If you get "Channel Not Purchased" for Choice XTRA Channels..... | SatelliteGuys.US
hantu
SatelliteGuys Guru
131
Rochester, NY
Ok,
I just got off the phone w/ Rita (CSR from D* with the sniffles :( ). I called her because I was missing DiscoveryHD TLC-HD, etc. Not everything, but just those in the Choice XTRA package.
RESULT:
If you have Choice XTRA (or have recently upgraded to it) and you are not getting the corresponding HD versions (DiscoveryHD, HistoryHD, etc), check your "Recent Access" list on your D* account at the website. If it doesn't say "HD Access - Choice XTRA", you may not get these channels by default. If you are in this boat like I was and need help, tell the CSR that you do not see the "HD-Access Choice XTRA" listed in your Recent Activity.
Doin' well now in MPEG4!!
Rock On!
Hantu
Munch Munch Munch......
Family program package+HD
