ImagineAsia on IA 13 - DVB-S | SatelliteGuys.US
WyrTwister
769
Presently viewing this channel and a few others on IA 13 on the 90 cm mini bud , DVB-S C band , with the 30 degree LNB .
Wyr
Now that is interesting...guess i will have to split off the c-band side to my FTA and check it out...been really busy learnig about the FTA stuff and cleaning up my old BUD!!!
Merry Christmas!
Jeff
Merry Christmas!
Jeff
Lyngsat lists quite a bit of digital c band . Will have to scrounge a larger sidh , in order to get more than a taste of it .
Wyr
I'm impressed that you were able to See ImagineAsian on the 90cm dish! I wasnt' able to see it's transponder at all with my 5' dish!
A couple gems on C-band DVB are Euronews and Fuse TV. Sometimes the Outdoor channel has some interesting stuff. It also has a HD channel in the clear for those with the equipment to receive it. I liked BBC World as well.
I need to get a DVB box again...
Supposedly an offset dish is more efficent ( mor signal for the size ) than a prime focus dish , because the arms holding the scalar ring , etc. are not in the way . The scalar ring , etc. are probably in the way too .
Also , if I had a scalar ring designed for offset ( instead of a prime focus ebay special ) , it would work better .
Maybe an older LNB problem ? Maybe the dish needs a tiny bit of tweeking ?
Think those channels scanned , and would come in part of the time . Signal strength & qualit was border line , and faded in and out .
Yes , picked it up a few times on Nexus-S PCI DVB card running in software mode ., again , border line signal .
Or a card , especially for HD .
Wyr
