imminent hard drive failure | SatelliteGuys.US
If you have an USB hard drive, you just have to plug it into the USB port, the 622 will ask if you want to erase it and format it for Dish. If you say yes, it will format that drive, then you will be able to move you shows from your internal drive to the USB drive.
Note, you cannot move timers from the 622, so make a list of them so you can make them over on the replacement 622.
Need help with Hopper with Sling installation
DIRT on today?
