In line Amplifier with stab hh120 motor mount | SatelliteGuys.US
charizma4u
5
I have a long run. maybe 85 or so feet.
I am getting pretty good quality on the signal around 80 but strength is always in the 60's.
can I use an in-line amplifier and still power and operate the motor correctly?
I am using a lavasat DISEQqC 4/1 with the v.2 sonicview that has DiSEqC 1.0, 1.1, 1.2 & USALS / 22KHz Switching Control.
What type of amplifier would those of you in the know recommend?
:confused:
Chariz
I have used a inline amplifier before, and my results were not significant, I think it actually made the quality a little bit worse.
I have learned over the span of three dishes that the only real way to improve quality is to align the dish better or upgrade to a larger size.
Quality is directly related to the signal to noise ratio, you can't get a better signal noise ratio by amplification, a amplifier will increase the noise too, so you need more signal.
What size dish are you using?
EDIT- when I re-read your post you say that your getting a good quality, quality is what matters, it does not matter that the signal reading is low.
If everything works, don't fix it ;)
Just to add to qwert1515's remarks, 85 feet is not very long. I have over 2 times that length with a couple switches and a couple barrel connectors inline, and have little problems. 250feet is what I'd consider a relatively long run - one that I'd make sure it's straight/uncut good quality RG6 (or better yet, RG11)
yes good quality rg6 is a must , preferably shielded 85 ft isn't long
so i would try better coax ( buy the best you can afford)
rg-11 will be expensive plus not many fitting tools will work with rg-11 ( so it would require a new tool or someone to fit the ends
Just double checking True South satellite for Alignment
Sunfade 2007 (Fall edition)
