Inactivity Stand by? | SatelliteGuys.US
blockisle9
217
Does anyone know what "Inactivity Stand by" is? the default is set for disabled. It seems like if it was enabled it would turn off the hard drive, there for increasing the hard drives life.
I would think this is happening now anyway, I have automatic updates enabled and after the updates every day Im getting the screen saver logo till I hit the select key.
I was told in the past that a computers hard drive would last longer if you left it on instead of turning the computer on and off all the time.
Lenny
It's a new feature added to automatically turn off the receiver if you forget to, basically it turns it off if it hasn't been used for a while
Any word on AT60 for $19.99
Problems with my reciever DVR 508
