"Ineteractive" weather on 722 | SatelliteGuys.US
stardust3
8,729
7,182
"Interactive" weather on 722
Anybody else not getting the "interactive" icon for the weather channel on their 722? I install for a living and have not been able to get this icon on any 722 I have installed including my own. I have not been able to get a straight answer elsewhere. I suspect it is a software issue. Any info would be appreciated, thanks.
Which channel are u talking about 214 or the HD weather channel! I can't get it either on the HD channel! Just checked, I'm getting it on channel 214, but not the HD version!
The HD version is the one in question.
It doesn't work on the HD version. I have better luck with the SD version of it. Of course, that doesn't work a lot of time either, so I access it through Channel 100.
Same thing with the interactive CNN and ESPN, they only work on the SD versions.
Silly question - since some people seem to get it and others (like me) do not - is there any chance that the interactive feature is only available in some markets?
Cost to downgrade to SD...
Dead 622 replaced with 722, no local ota guide info???
