initial install with planning for system extension (adding recievers) | SatelliteGuys.US
rhapsody
56
East Tennessee
I am about to order Dish service. However, I am tooling with the idea of getting the 722K reciever for one HD set and one SD set. However, if I want to add another 722K later, what will happen?
Will an installer need to come back out to run an addition set of lines for the new 722K (or maybe 922K if its out by then)?
Thanks so much.
there will be another set of lines needed to be run, but there is a do it yourself option:
run a cable (rg6) from the dish to the room where the X22 is, have dish send out a dish pro plus separator. to connect this you need 2 short rg6 cables from the sep to the sat in 1 and 2. then you can run the 2nd tv's cable from home distribution on the rcvr to the 2nd tv
dish will setup a service install/and or upgrade for your additional 2 rooms.if that happens,then the installer has the separator.BTW the line are included in the cost of the SC.
VIP 922 Functions
error code 614
