Inside the HD-XA1 HD-DVD player | SatelliteGuys.US
Ilya
XXI Century Explorer
Staff member
HERE TO HELP YOU!
32,641
21,043
NE OH
Curious to see what's inside the HD-XA1? Japanese website watch.impress.co.jp posted some pictures and a detailed review:
Original website
CPU seems to be Intel Mobile Pentium 4 2.5GHz...
Automatic translation by world.altavista.com/babelfish:
In a general way being the place where it finishes using function, it tried looking the content of HD-XA1 simply.
Already, for the home appliance of Intel it has been publishedplatform "Intel 854 " to the base, thatthe decoder tip/chip of NEC make drive andBroadcom make is loaded, but at the point where also structure and the like of the chassis becomes matter of concern.
First, removing the screw the rear, it tries opening the chassis. The cover whose substance top is black thought, when it is the metal make from feeling and material feeling, selfishly, but the fiber reinforced plastic (ABS) with, removing, when it tries hitting, the sound which the plastic seems does. Recent plastic process technology admired that they are enormous ones.
When the cover is removed, the chassis cover of the steel appears. When this cover is removed, you can verify the main baseplate and the like. The chassis is designed to be two-layer structure, CPU and the decoder tip/chip, it seems that has HD DVD drive and output system on the lower stratum in higher stratum of society. As for the chassis the lower stratum method of opening did not understand.
CPU which has the fan and the tip/chip etc. which has the large-sized heat sink are visible in the baseplate of main. When it tries removing CPU with Intel make of 478pin, as for the sSpec number which is stated "SL6WY". When with Processor Spec of Intel Finder it searches,it seems like MobilePentium 4 2.5GHz.
You knew the Intel base, but when you think of that the separate decoder tip/chip is loaded the high clock CPU is stacked with did not think to here. When, just baseplate such as IO controller and the memory of Hynix sees, it seems like the personal computer.
Exceptional electric power consumption and, having used as the player, 79W, also the fan noise which has become matter of concern, agrees upon that you look at this constitution. But, because it is the part which relates to the use impression directly, whenever the generation is piled up, it is about to want advancing improvement.
vurbano said:
LMAO. This sounds like the responses to questions about the Linkplayer2 on the IODATA website. Too funny.
Hey guys, I worked for two different Japanese companies in the hotel business. I don't speak Japanese. You should try figuring out what it they want you to do when they speak English to you like that. :p
