Well here is the prelim stuff from the inside of the VOOM Box, to begin with it is very very close to the star choice DSR500, other then the added expansion slot which turns out to be a PCMCIA footprint with a extra long slide and a riser board to connect the 8VSB module(s). Also like the DSR500 there is room on the board for another sat-tuner and also extra room for a 2nd 8VSB module. Room enough for internal harddrives but NO apparent connectors on the MB for harddrives. I suppose the PCMCIA slot could except a harddrive but at this time that kind of drive is extremely expensive I from a engineering standpoint don't think they had that in mind. Other uses for the pcmcia slot have been rumored for a upcoming mpeg4 decoder.
Here are the major chips;
MB87F2011 - ICAM Chip
XC 420061-005 GIC 1998
MD-2811-D32-V3 MSYSTEMS DISK-ON-A-CHIP
ISP1561BM PHILIPS
BCM7501KFB BROADCOM
XC2S200E XILINX SPARTAN FG456AGT0333 D2142451A FPGA
Here is also a pix of the MB, I have many more detailed pix's (16mb worth) if someone would like to donate some server space.
Hope this helps!
GG
http://www.satelliteguys.us/forum2/download.php?id=472
ISP1561BM PHILIPS
BCM7501KFB BROADCOM
Hope this helps!
GG
