Ordered Genie and 2 C31 (clients) for three rooms. I would like to have wiring ran in the attic instead of outside house.
1) How many cables come from the disk and where does each cable need to go to connect to the Genie and the two clients. I am not sure who many cables go where?
2) Two TV's are located more in the center of the house and need to have wire "fished" down walls. I was planning on running tubes (actually pex tubing) down two interior walls where cables could easily be fed to connect to the Genie in one room and client in another. Would installer allow time for me and a friend to fish cable down wall and work in attic?
3) I have an existing antenna on one end of the house where it is easy to get to cables and room to work on, but the disk may not be able to be located there because there is a hill behind my place on that end. Placing the disk on the other end of my house would probably work better for satellite reception, but wiring in attic would be difficult (heating ducts, insulation, etc.). If the DirecTV installer and I can't agree on location of disk and wiring of system unless I prewired in attic space and fish wires ahead of time, would they charge for a 2nd visit?
