Install problem with dedicated 3ABN system | SatelliteGuys.US
sweatherbie
5
Lancaster, Pa
I am having a problem with one of my installs and need some advice.
I am using 2 Fortec Star Lifetime Ultra's and a Geosat pro sl2-bullet LNBF for AMC4 Adventist TV.
1 room is diplexed with digital cable and am getting great signal and quality, the other room was diplexed and rarely would lock in. I direct connected that room to the LNBF and signal would lock but had a lot of digital artifacts, switched LNBF ports and signal locked on the receiver I was origionally having problems with but lowered or lost completely on the receiver that I had no problems with. I tried 3 other SL2-bullets with same results.
What have I missed. They both work great seperately with or without being diplexed, as soon as I combine them that's when my problems start.
Can you help?
Take Receiver, Diplexers, and Cables from that room to the room you are having a problem.
Thinking possible bad connection / cable.
Double check that the cable is RG6, and not RG59
Boy do I get kinda lucky on Craigslist with Satellite stuff..
97, 101, 123
