Install question | SatelliteGuys.US
Install question
will_blueprint
4
Hi I recently purchased a new condo unit and I am heavily leaning towards a dish install. It is a brand new condo unit, that has the cable wires run already. Will the installer have to run new wires, or can he tap into the cable input going to the house. Thanks.
Condo Units are different from home. Your Outlets go Directly into the Street Distribution box of the cable company. If you want a Dish installed, it might have to be installed in your balcony unless you have a special approval to have it installed in the roof.
Uh..!
I explained that to a customer. He told me not to worry he would have cable where I could connect his TVs to the DTV dish. I never asked and he never told.
Joe
Fx Hd
Still waiting for your RSN in HD? This info seems accurate.
