Install scheduled tomorrow-have ? | SatelliteGuys.US
dspon
29
Central Ohio
I am having my superdish reinstalled after 3 months of voom. From past exp. I don't have a lot of confidence in the installer. I have 2 hdtvs and mmay ad a sd tv in a remote room in the futere. I have a 942 and the installer is bringing a 811. I want to keep the winegard ota for hd locals. Is there a reccommed sight for suggested diagram connections? I will want the capability of 4 receivers since the 942 asks for 2. Please help
Good Luck you will need a DPP44 for your 4 satellite locations and probably a DNSC supervisor so you will have someone that knows what they are doing.
install went ok
Did have install. It took about 5 hours. Tech had to use a #44 switch and run a seperate line from the oat. We reused the voom dish and he installed a dish lnb. Installer was dish only and had to make a few calls but he stayed with it. :)
Another rebroadcast spat Dish V. Sinclair
fox reality channel
