Installation For HD | SatelliteGuys.US
Installation For HD
royd
23
I'm getting a 622 install
How can I find out if its a 61.5 or 129 install
I will need to cut down trees for ether and would like to do this before the install
the 129 would be very difficult And I don't want to cut it down even if I can
119 Just makes it but is fine
The Dish site said 61.5 First CSR said 129 Second CSR said 61.5 and third said
HD is on 119 All three sounded clueless
Should I just cut down the two trees for 61.5 LS and hope the installer brings whats needed
I'm in SW Michigan
rbsixpak said:
go with 61.5 ...its the highest elevation and much easier to peak. just tell tech u want a 2nd dish
Good luck with that - unless you ordered from a LOCAL GUY.
A DNSC hack is going to bring a Dish1000 (129).
OK
Was Getting ready to cut some trees for 61.5 when a van pulls up
Its a dish installer DNSC He is lost and a day late and they don't answer
So while he's here I asked him they only do 129 Dish 1000
He did point out a spot I may have LOS
And they don't have any 622'S Should be sent by Dish
When I told him that wasn't the case he said OK maybe
but He had not seen any or done any 622 installs yet
So If I do have LOS for 129 I'll check shortly it will need a pole mount
and cable to the other side of the house
Think I'll mount the pole and run a cable from the TV to the ground block
Get the hard part out of the way
Install date is July 10 And taking a day off work for this better have a 622
Dish needs CS for installs like someone in India gives a ####
OTA question
Can't take it anymore!
