Installation of a VIP222K using a 1000.2 Dish | SatelliteGuys.US
RCS71
3
Midwest
Is there somewhere I can get instructions on wiring.
I have a 1000.2 dish with a Proplus triple LNB.
I am not sure what lugs on the LNB to connect the coax to.
Also, I with my 222k i received a splitter that has 3 coax cables that connect to the receiver and one lug to connect the coax from the dish. Does a single wire from the LNB connect to this?
That "splitter" looking thing is a separator and you need to use that at the back of the receiver. The two short cables connect at the sat in ports and the cable from the dish connect to the single port on the separator. Be sure to run a switch test.
PTAT not ready for prime time (or bad Hopper?)
Front Panel USB port
