Installation Question 1000.2 West Arc with hopper and solo node | SatelliteGuys.US
chapin4life
91
I'm doing my own installation i have a 1000.2 W (110,119,129) solo node, 1 hopper and 2 joeys
my question is that the lnb has 3 outputs but the solo node only has 2 inputs
did i get the correct switch, or do i need a duo node?
Use two outputs from the dish to the solo node.... All will be well.... You only need the third if you have two Hoppers and a duo node....
On which sat should i lock first 110 or 119 to catch 129?
on the hopper on satelite options i dont see 129 only 121
With a plumb mast and the right skew, peak on 119 and the other two should fall into place. Sometimes you can tweak the skew, especially if your mast isn't plumb.
Sent from my iPhone 4S using Forum Runner
ViP722 + 4 port USB hub = SUCCESS!
Stupid question. How to enter 412-24?
