Installation Question | SatelliteGuys.US
druwhall
13
Lexington
I'm getting only 2 receivers set up tomorrow for my installation. Should I and am I allowed to get other rooms set up for future receivers?
You probably should've gotten all the additional SD receivers that you could for free for any room that you might want any receiver in eventually. Then after the install you could deactivate them and send them back since it wouldn't have cost you anything up front anyway. I doubt the installer will run coax to rooms where he isn't hooking a receiver to, unless you tip him very well.
Do you have wiring already into the other 2 rooms.
For me, I have 3 receivers, but 4 rooms hooked up, the installer hooked the extra room no problem. Not sure if he will run new wiring, but its worth a shot.
Thoughts on HR22/New Install
on-demand error codes DirecTV has never heard of
