installation | SatelliteGuys.US
installation
Albintv
After inst. two receivers a 625 & 322 i'm having trouble getting them to do a switch check. Both of them will not read 110 and 119. Is there a certain procedure you need to do to get them set up? Please help. thanks
Dish not aimed will give this problem, switch not hooked up correctly will give this problem, using the wrong lnbf versuses coax hook up will also give this effect, using damaged or incorrect coax will give this effect, contaminated connections will give this effect, splitters in line from the dish to the receiver will give this effect, not knowing what your doing will lead to all of these giving this effect.
What we need from you is details to the installation, how is the dish mounted, is the line of site to the south south west clear, are you using rg-6 coax, are you using twist on fittings or compression fittings, are there any splitters in the lines, what lnbf / switch configuration are you using, ect ect ect.
Sounds lie you not pointed at the Birds (119 & 110). When you run a " Check Switch" do the receiver recognize the Twin and or Switch? If so, you need to re-peak the dish. Sorry, but if it was only one receiver it would be equipment. Hope this helps!
Yes, looks like none of the satellite detected, if the install done by installer, it must be a hacked job. or you did it yourself.
Same thing I was thinking, give us more details?
Stupid 811 remote question
dish 522 remote
