integrated multiswitch dish outputs | SatelliteGuys.US
jiggs86
Hello all! I recently had a 3 LNB antenna with an integrated multi-switch installed. It has 4 outputs. But I want to wire in (2) DVR's and (1) Receiver. That require's a total of (5) outputs from the multi-switch.
Does anyone know I can install a multi-switch in series with the one that's intregrated on the dish? Or how I can get (5) outputs from the dish's integrated multi-switch which only has (4) outputs? Thanks, David
You would need a 5x8 multi-switch. Take all four wires from the dish to the four ports in on the switch,this will give you eight outputs for up to eight boxes or four tivos or etc..
Hope this helps you out.
