Intel NUC experiences? | SatelliteGuys.US
John Kotches
6,765
197
Troy, IL (STL Area)
Does anyone have experience with the Intel NUC line of systems? Could be perfect as a hypervisor with a few VMs for certification testing practice.
Thanks for any experiences you can share.
I use a couple of the older i5 models as HTPC. Ive been quite happy with them.
Steven:
Thanks -- the low heat is important. We recently downsized houses and the server I use for learning is just not cutting it any more ;)
Have you looked at the HP MicroServers? They are a pretty decent value and would give you some expandability.
Steven:
I haven't. I'm not particularly enamored with HP machines. But I will check it out. Key thing here is $$$$.
I'll be reusing SSDs and once I pass the certs I will probably use it to replace the raspberry pi. I'm sure I can repurpose the pi for something else.
Sent from my SCH-I605 using Tapatalk
I'm not sure how many VMs a NUC could host. We were looking at the NUC for Executive desktops with the VESA mount to provide an All-in-1 look without the all-your-eggs-in-one-basket costs of one.
Foxbat:
These are just test beds for certification testing and experimenting with some newer options like CoreOS. Not for anything resembling massive virtualization -- I don't require lots of cycles and I don't require gobs of RAM.
I ended up with a can't beat the price dual socket quad core XEON Dell workstation for this.
When it's done I can make it into a hackintosh Mac Pro workstation.
