intelsat 5 with what settings pansat 2700a?? | SatelliteGuys.US
shahdad
30
intelsat 5 w/ pansat 2700a?? anyone???
Im pointed in the right general direction but sill nothing!
its not as easy as getting echostar 7, with dish 500 lnb and dish, you can be off by a lot and still get signal, and all i do is move the dish up and down and along the path i get a signal.
with IA5 how spot on do i have to be? and how long does it take for the reciver to respond?? in other words, how long do i wait at each increment of movement?
and what about skew, im set at zero, and the lnb is pointed up right, is that right?
im located in vancouver bc,
any help?
intelsat 5,will i hit nimiq 1 or galaxy 3?
im still having problems hitting it.
if i hit nimiq 1 or galaxy 3 will i get an increase in qaility with the pansat 2700a?
or will the quaility only move if i hit intelsat 5?
and whats with the signal, it stays at 27% even when quaility is 0%
i used to have bell @ nimiq 1 with dish 500 dish and lnb, how far is intelsat 5?
What size dish are you using?
What kind of LNB are you using?
i have a digiwave standard single lnbf and 33" dish
i am using a pansat 2700a.
i cant seem to find intelsat 5 so i was wondering if i am searching the sky and happen to come accross galaxy 3 will the quaility level go up?
Too say it another way you are use to finding the Moon now you have to find Mars if we compair strenght of nimiq 1 with lower power sats.
Get a signal meter and a printout of your sat locations. They sell them on ebay for less than $20 inc shipping.
What is your zip?
lol, i like ur analogy.
i refuse to give into a signal meter, haha!!! never
no i know that what i will have to do.
my zip is a postal code, its v4c5n3
ive got my directions correct. i used to get nimiq1 with a dish 500 and IA5 is just a bit off so i know im in the right direction.
one question though, what about skew angle, would that make a difference??
thanks
Delta BC.
Code:
          Latitude 49° 0.000'N Longitude 123° 0.000'W
              Sat Name Sat Lng Az(t) Az(m)   El  Skew
*** ALL DBS SATELLITE ***
            EchoStar 3   61.5W 112.3  92.7  9.7 -37.4
          EchoStar 6/8  110.0W 163.0 143.4 32.4 -11.1
          EchoStar 5/7  119.0W 174.7 155.2 33.6  -3.5
 EchoStar 9/Telstar 13  121.0W 177.4 157.8 33.7  -1.7
          EchoStar 1/2  148.0W 211.7 192.2 28.9  20.2
            EchoStar 4  157.0W 221.8 202.2 25.1  25.9
     DirecTV 1/1R/2/4S  101.0W 151.8 132.3 29.9 -18.0
             DirecTV 6  110.0W 163.0 143.4 32.4 -11.1
             DirecTV 5  119.0W 174.7 155.2 33.6  -3.5
*** All Satellites 61W - 160W ***
              Amazonas   60.0W 111.0  91.5  8.7 -37.8
             Rainbow 1   61.5W 112.3  92.7  9.7 -37.4
              Nahuel 1   71.8W 121.2 101.7 15.9 -34.1
           DirecTV 5/1   72.0W 121.4 101.9 16.0 -34.0
                 AMC 6   72.0W 121.4 101.9 16.0 -34.0
             Galaxy 12   74.0W 123.3 103.7 17.2 -33.3
                 SBS 6   74.0W 123.3 103.7 17.2 -33.3
                 AMC 5   79.0W 128.0 108.5 20.0 -31.1
             DirecTV 3   81.8W 130.8 111.2 21.5 -29.8
               Nimiq 2   82.0W 131.0 111.4 21.6 -29.7
          Brasilsat B3   84.0W 133.0 113.4 22.6 -28.7
             XM 3 Roll   85.0W 134.0 114.5 23.1 -28.2
                 AMC 9   85.0W 134.0 114.5 23.1 -28.2
                 AMC 3   87.0W 136.1 116.5 24.1 -27.1
              Galaxy 9   91.0W 140.4 120.8 26.0 -24.7
             Galaxy 11   91.0W 140.4 120.8 26.0 -24.7
               Nimiq 1   91.0W 140.4 120.8 26.0 -24.7
          Brasilsat B4   92.0W 141.5 121.9 26.4 -24.1
             Telstar 6   93.0W 142.6 123.0 26.9 -23.5
             Galaxy 3C   95.0W 144.8 125.3 27.7 -22.2
             Telstar 5   97.0W 147.1 127.6 28.5 -20.9
             Galaxy 4R   99.0W 149.5 129.9 29.2 -19.5
             DirecTV 2  100.8W 151.6 132.1 29.9 -18.2
            DirecTV 1R  100.8W 151.6 132.1 29.9 -18.2
                 AMC 4  101.0W 151.8 132.3 29.9 -18.0
             DirecTV 1  101.0W 151.8 132.3 29.9 -18.0
                AMSC 1  101.1W 152.0 132.4 30.0 -18.0
            DirecTV 4S  101.2W 152.1 132.5 30.0 -17.9
                 AMC 1  103.0W 154.3 134.7 30.6 -16.6
              AMC 2/15  105.0W 156.7 137.2 31.2 -15.0
               Anik F1  107.3W 159.6 140.0 31.8 -13.2
             DirecTV 6  109.8W 162.7 143.2 32.4 -11.2
            EchoStar 6  110.0W 163.0 143.4 32.4 -11.1
            EchoStar 8  110.0W 163.0 143.4 32.4 -11.1
               Anik F2  111.1W 164.4 144.9 32.6 -10.2
         Solidaridad 2  113.0W 166.8 147.3 33.0  -8.6
               XM Rock  115.0W 169.5 149.9 33.2  -6.9
              SatMex 5  116.8W 171.8 152.3 33.5  -5.4
            EchoStar 7  119.0W 174.7 155.2 33.6  -3.5
            EchoStar 5  119.0W 174.7 155.2 33.6  -3.5
            Galaxy 10R  123.0W 180.0 160.5 33.8   0.0
             Galaxy 12  125.0W 182.6 163.1 33.7   1.7
          Galaxy 13/H1  127.0W 185.3 165.8 33.6   3.5
   Telstar 7/EchoStar5  129.0W 187.9 168.4 33.5   5.2
                AMC 11  131.0W 190.5 171.0 33.2   6.9
             Galaxy 1R  133.0W 193.2 173.6 33.0   8.6
                AMC 10  135.0W 195.7 176.2 32.6  10.2
                 AMC 7  137.0W 198.3 178.7 32.2  11.9
                 AMC 8  139.0W 200.8 181.3 31.7  13.5
             Galaxy 14  146.0W 209.4 189.8 29.6  18.8
            EchoStar 1  148.0W 211.7 192.2 28.9  20.2
            EchoStar 2  148.0W 211.7 192.2 28.9  20.2
Satellite Finder is (c) Copyright 2004, P. Lutus
i know that, the dish 500 was an example of ease
trying to get ia5 with 33" dish and digiwave standard single lnbf
question is, is it as easy as getting echostar 7?
and with a singal meter will i get a signal even if my skew is not set right?
According to this website:
http://www.geo-orbit.org/westhemipgs/ft5p.html
Your 33 incher may be a bit small to pick it up from your location.
Try to find this transponder - it is as hot as a pistol.
TP3 -> 11789V -> SR=25000
Good Luck...
I know this looks goofy but I merged your two threads...please keep the same topic in this thread :) (makes it easier to follow and then people wont ask questions that shouldnt ne...I didnt know you had a 33" dish until I read the other thread) :)
Universal LNBF's - Good or Bad?
Dead Pansat 2500 - Do Not Send to Pansat
