Interchangeability of External HDs on 2 ViP211ks? | SatelliteGuys.US
don8ch
5
mississauga
I have 2 ViP211k receivers and identical WD My Book Essential 1TB drives for each. (2 receivers + 2 external hard drives) My wife had me record several programs on "my" receiver but would prefer to watch them on the big tv. Can I swap the hard drives between the 2 receivers without the dreaded reformat?
If the answer is yes I assume that I should power down the receivers and the external drives prior to doing the swap then restart?
Thanks,
Don
I never had a 211, but if I recall, you do need to re-set the 211 to swap. Not the EHD.
Actually there should be a menu option (if I remember right) about safely removing the drive (just like on a computer)
Thanks to all for their replies. I was previously concerned that the "Remove DVR" was a permanent removal rather than a "safe to remove DVR" type of message.
Thanks,
Don
DVR schedule disappeared plus one other question
Extending a recording in progress did not work
